turboporsch wrote:Do you have any idea how to remove radio/cd or peripherals to get to the antanea wire to install the fm modulator for Sirius?
Not sure on the 06. It might be easier than on the 04-05 as it looks like the 06 has a seperate piece for the stereo. It might just be a matter of popping it off. The 04-05 required the lower dash on both sides to be removed to access screws and the clock and upper instrument panel as well as there was a screw holding the main bezel down as well.
And why do you need to use a FM modulator? IIRC, all but some early models are prewired for SAT. All you would need is a compatible SAT unit and antenna and you plug it into the harness next to the spare tire in the trunk.
