Interior lights in 03 Murano
Forum for the unique Murano, and official home of Nissan Murano Club!
driver13
Car: 03 Murano
The map lights and all dome lights do not work. Have checked the fuses, circuits and bulbs with a meter. I see others have had this problem. Has anyone discovered a solution?
8675309yine
Car: 2005 Nissan Murano
1988 Thunderbird Turbo Coupe
2005 Pontiac G6
I stumbled across this answer, Hope it helps, Looks like its from a Nissan Master Mechanic:
The engine fuses in the clear plastic are your main powers for the fuse box , the best way to inspect fuses is with a test light make sure they have power on both sides of the fuse ,if there is no power at the fuse the engine fuse could be bad, if it is the BCM is replacedhttp://www.justanswer.com/ques...-gone
Good Luck!!"86"
Return to “Murano Forum”
