SuBXeRo »
https://forums.nicoclub.com/subxero-u95987.html
Sun Sep 20, 2009 8:23 pm
i think those switches are 16 amps at 12v, i had them in my old car, good switches. you can probably wire uhhh well at 20ma an led, thats 50 to an amp, so 16 amps is 800 20ma LEDs.
when i wire leds, its all application dependent, if its a 3rd brake ligght i use a pc board and solder it on and stuff, if its free form i isually solder a resistor to each led or run them in series to create a 12 to 14v load. You will have to play around with hiding the wiring, all i can tell you is that you become a better wirer the mosre you do it and as you learn tips and tricks along the way.
Also, buy the oznium LEDs, phil doesnt f*** around with the quality of his LEDs that he buys.
