gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Tue Nov 16, 2004 8:03 pm
Problem fixed. Here's what I did.
1st Step: I replaced all of the tail light bulbs. Yes, the old bulbs did have melted tips. I used Sylvania LL's. Result- Didn't work.
After being a little pissed off and throwing a quick temper tantrum I started thinking really hard about what the problem could be. Remember, I'm not very mechanically inclined.
2nd Step: I wiggled the connector wires going into the tail lamp assemblies. Of course that didn't work.
After step 2 I remembered I emailed myself a copy of the fuse diagram in the dash area from ALLDATA at work a few months ago (I don't have a diagram on my fuse box door).
Step 3: After finding the email I sent myself and printing out the diagram, I noticed the 10A fuse that says "Side marker lamp, License lamp, Glove box lamp, Illumination lamp, Tail lamp". I then went into the car to verify whether or not the Glove box lamp was also out when the headlights are on. Yes, the glove box lamp was off along with all the others mentioned. Replaced the fuse and BAM! Problem solved.
I know it doesn't sound like much but I just got my car out of the shop last Friday after it had been there for a week. I wasn't ready for it to go back in again. I have to thank you guys because I wouldn't have checked the tail lamps at all if it wasn't for you. I even got an extra step out of this because now I have all new unmelted bulbs too! Problem is, my Stop Lamp Indicator is still on can't figure that one out.
Now I'm just wondering, could the overheating of the bulbs have caused the fuse to blow?
