Blackmobile »
https://forums.nicoclub.com/blackmobile-u106210.html
Mon Jan 11, 2010 9:46 pm
to wire up the switch to your lights, here's the setup:
to wire it to a power source, you can either tap into the a fuse or wire which you know comes on when the car turns on. many people use the fuse from the cigarette lighter from the cubby hole. for the ground, you can connect the wire to the bolt in the fuse panel under the steering wheel as shown here: (not my pic, taken from the other altima site)
hope that helps
