Interior Color Code in Part Number?
DAZVI
Does anyone know if the part numbers indicate the color of the item? For example, I see an item called "Tray-Rear Floor" and has multiple part numbers; 84950-30P00, 84950-30P01, 84950-30P02 and 84950-30P03. The descriptions do not specify which color it is but I know 30P00 is black. I have an OEM trunk carpet in blue that ends in 30P03 so I am curious if 00 indicates black, 03 indicates blue and 01 & 02 would be tan or red maybe.
Any help would be greatly appreciated
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That's a good assumption. Parts that come in different colors always have different part numbers for the various colors (although there's no fixed scheme for which digit will differ). Sometimes there will also be an "unpainted" version as a default and then pre-painted versions available, that's common with things like door handles and mirror caps.
DAZVI
VStar650CL wrote:
Sat Aug 27, 2022 4:12 pm
Thank you for the reply. When searching by the last half of the part number it looks like when it is an interior part it does designate color but it can also be used on many non-interior parts as well. I have blue interior so this could help find parts in the rare event there are still.any around. Thanks again
