paperfootball »
https://forums.nicoclub.com/paperfootball-u68511.html
Mon Nov 12, 2007 3:26 am
The *new* armorall is a water-based silicone emulsion and is fine for use on all vinyl/plastic. The early formulation (in the 80's) was a dimethyl silicone, slovent-based product that would indeed dry out vinly and plastic. I personally do not dress my interior, but rather wipe it down with a damp microfiber, or Meguiars interior quick detailer. If I was going to dress the interior of the M I would probably use 303.
As for the leather--it is coated leather, Lexol was actually developed for uncoated leather. It will not harm it, but IMO should be used on what it was designed for. It is actually more important to keep coated leather *clean* as opposed dressed. Most leather failure is caused by oils in the body left on the leather, which turn to acid and begin to attack the coating. I would recommend wiping the leather *at least* weekly with a damp microfiber towel--pay close attention to areas that come into direct contact with the skin. Dress the leather as you see fit with any product that is desgned for leather--even a few times a year is fine. I personally use a product by leather masters, but really anything will work. Be careful around the perforated areas as they will collect dressing if applied too thick.
