Interior AC fan won't work.
Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
kfountai
Car: 2012 G37 Convertable
I have checked the fuses, where is the fan located? Is there anything else that I should check?
ca18det_boy
You can check the connector going to the fan itself under the passenger side of the dash. Pull the plug, turn your fan on, and check for power going to it. That would be my first step.
telcoman
kfountai wrote:I have checked the fuses, where is the fan located? Is there anything else that I should check?
I assume you are referring to the blower motor?
Have you followed the troubleshooting steps in the FSM?
http://www.nicoclub.com/service-manual? ... e/2012/HAC
Start reading on page HAC-041
The blower motor fan is located behind the glove box
I assume you've never changed your cabin filter otherwise you would have seen it
You may want to leave this troubleshooting to a pro?
Just my $.02
Good luck
Telcoman
kfountai
ca18det_boy wrote:You can check the connector going to the fan itself under the passenger side of the dash. Pull the plug, turn your fan on, and check for power going to it. That would be my first step.
Finally got to her car. Pulled plug and got power. I can hear the seat fan when it is on high.
Seems to be the blower for the cabin. Thanks.
Return to “G37 Convertible Forum”
