elbles »
https://forums.nicoclub.com/elbles-u3033.html
Thu Dec 04, 2003 6:22 pm
Well, if you are referring to non-interference engines, Toyota has at the very least the 5SFE, 3SGE, and 3GSTE, all of which are non-interference, meaning if the timing belt breaks (all of those engines have belts rated for 60K miles), the valves will not meet their death by hitting the pistons, or vice-versa; most, if not all, Nissan engines are interference, meaning that if the timing belt or chain breaks/jumps teeth, et cetra, the valves will hit the pistons (or vice-versa), and you'll have a much more expensive repair bill. ;-)
Interestingly enough, quite a few people tout chains as being better simply because less maintenance is "required", but in at least 3 Nissan engines that I'm aware of, there have been some pretty interesting problems related to timing chains, with the KA24E, KA24DE, and VH45DE (or whatever engine was in the 1990-early 1993 Q45's) all having problems with chain guides, et cetra. Because of stuff like that, I'll take a non-interference belt engine anyday, hehe.
