SHIFT_Z »
https://forums.nicoclub.com/shift-z-u3748.html
Sun May 11, 2003 10:55 am
Getting your tires to spin and or leave marks also depends on the road conditions. (Dust, moisture on road..?) If you can only get your tires to chirp but not give a solid peel, it may be because of the weather..? (the rubber would be cold and harder, and the road colder, thus easier to spin on a cold day)About the weight- Less weirght would help a lot, but you would see a large difference if you took like 500 lbs off your car.
