interesting!
I am Technoman
Car: ???
more good reading from twinturbo.net
I can't vouch for the accuracy of all these statements, but they have to be true if they're written down, right?
* One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona.
* Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747, but with 4times the energy volume.
* The supercharger takes more power to drive then a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition.
* Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitro methane measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at1400 degrees F. The engine can only be shut down by cutting off it's fuel flow
* If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this sentence
* Top Fuel Engines ONLY turn 540 revolutions from light to light!
* The redline is actually quite high at 9500rpm.
* To give you an idea of this acceleration, the current TF dragster elapsed time record is 4.477 seconds for the quarter mile. This means that you could be coming across the starting line in your Stage IX + 300ZX Twin Turbo at 200 mph (on a FLYING START) and the dragster would BEAT you to the finish line FROM A DEAD STOP in a quarter mile distance!
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
awesome
Rockenreno
Car: 1997 BMW M3
I know that at least some of that is true. It's amazing what those beasts do, but can they take a turn at that speed?I think not. :D
I am Technoman
Car: ???
I'm thinking about a dragster drifting.:crazy
s14kaibigan
Seeing what you can do in the 1/4 going sideways?*in a whispering omniscient voice*"If you can do it, they will come."
S13Ka24e
Car: Tunning, reading, learning
Most of that stuff sounds true, but i know that $1000 per second is wrong, the term i usually hear is with parts/fuel/tires (no labor) it cost about $4k per run. It only cost about $400 for fuel per run.
Tino
Car: Raising Hell
I am Technoman wrote:I'm thinking about a dragster drifting.:crazy
It woudln't be called drifting. More like the high rise roll and tumble.
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
S13Ka24e wrote:Most of that stuff sounds true, but i know that $1000 per second is wrong, the term i usually hear is with parts/fuel/tires (no labor) it cost about $4k per run. It only cost about $400 for fuel per run.
Fine, it costs 895$ per second of the run then.
Gregariousgreg
Car: Cars, snowboarding, psychology
That's why I love going to SIR.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
the shock of the parachutes opening up cause retinal damage (it meens you go blind if you do it enough)It like taking off in a space shuttle horizontally. the ultimate rush basically.
pgt892
Car: 1997 240SX
I am Technoman wrote:* The supercharger takes more power to drive then a stock hemi makes.
I know this is true. Of the 3000HP a top-fuel dragster makes, it takes about 1000HP to drive the supercharger. Those cars are so insane!
driftaholic
Car: '91 Nissan RM S13
i wish my 240 had 3000 hp. :D
SmithSR
Car: 240sx
anybody seen what happens when the rear wing breaks off of a TF dragster???
amazing... a vehicle that actually needs a wing, and for *gasp* downforce.......? wowsers.
Kaioshin1982
Car: Not a 240 =) Thinking of getting one again...
anyone got a pic of this "dragster" or a video?
I am Technoman
Car: ???
Kaioshin1982 wrote:anyone got a pic of this "dragster" or a video?
This is all "Top fuel" dragsters.
NIGHTfall_240sx
Car: Nissan S14 [notchtop SR] SOLD
i love the rush of speed man, but hitting 300mph within 5seconds... i would just sh1t myself
SmithSR
Car: 240sx
yeah man, this is usually in a highlight reel, or some car documentary, or some similar show. i thought it was widely known that a TF "dragster" will lift off when the rear wing breaks. downforce is cool.
