Interesting SmartKey Observation
BlackNWhite
Car: 08 Altima Coupe
Ok, so go ahead and delete this if this has already been mentioned before... but I don't believe it has.
On Saturday I was able to turn on my engine without having the smartkey in the cabin. Here's how...
Ok... so INITIALLY I DID use my key to turn on my car. I went with my gf from her house to my house. When we got to my house I gave her the keys outta my pocket so she could open the door to the house. My engine was still running at this point. I moved my car a little further up the driveway and when I finally got to where I wanted to park it... I turned off the engine BUT I left it in the ACC mode so the radio was still on.
Before I turned the car off all the way, I remembered that I had to park my car in reverse. At this point the car is still in ACC mode with the radio on with the NO KEY warning flashing. I stepped on the brake and pushed the start button... AND THE ENGINE TURNED ON.
I was a little amazed so I moved the car how I needed it to be, turned the engine off and again left it in ACC mode. Once again with NO KEY flashing, I stepped on the brake and pushed the start button and just as faithfully as always, the engine turned on.
So what I figure is that obviously you need the key to start the engine for the first time. After the initial start... as long as you don't turn the car off ALL THE WAY, for example leaving it on ACC for the radio... you can turn the engine on by stepping on the brake and pressing the start button ALL WITHOUT THE KEY.
Haha, just an FYI. This might come in handy if you ever SOMEHOW turn on your car and leave your keys somewhere. Go somewhere and realize you don't have your keys before turning it off so you can leave it in ACC mode so you don't get stranded.
phobs
oo interesting, I'll try this out with my car :D
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
good info, thanks
dnasty88
Car: 2008 Infiniti G35x Sedan Liquid Platinum
how to you turn the engine off from on to acc? mine goes straight to off.
CaLiLaTiN
Car: 2008 Nissan Altima Coupe, Premium Package.
interesting. Im going to try it too.
08Coupe
Car: 2008 Altima Coupe
It's like a car jackers wet dream!
marlin29311
I think it workded techinically because you turned the car "on" with the key and the car was in "on" mode. You can't get too ACC without the key, and seeing that the car was in that state, you can jump to whatever "on" mode you want from there.
Interesting find
BlackNWhite
^That's the same assumption I came away with. As soon as you go to OFF without the key... you can't do anything. As long as you have SOMETHING on, even without the key, you can turn the engine on.
And I agree with the person that said this is a carjacker's dream. Before I realized this, I would always leave my car with the radio on while washing my car and I would walk away from it with the keys in my hand thinking it was safe. If someone had just jumped in and pressed the brake and push button... they'ld be off with my car. Hopefully the 'NO KEY' warning sign would've scared them off.
dnasty88 wrote:how to you turn the engine off from on to acc? mine goes straight to off.
When the engine is on... you hit the button once to turn it off and once to go to ACC mode. The trick is you have to do this quick. Sorta like when you double-click on the mouse. If you do it right it goes from ENGINE ON to ACC while skipping the OFF mode.
windex
Car: 2008 Altima Coupe 3.5SE
I tried this last night and my car didn't start after being in ACC mode. You may want to make sure your spare key isn't in the car.
BlackNWhite
My spare key is in my room. I don't believe the dash would say 'NO KEY' if my spare was in the glove or somewhere else in the cabin.
windex
Good point missed it. Anyone else tried this out?
dnasty88
sweet. does it like keep the radio on and stuff or off and back on fast?? ive always wondered how to do it because if im listening to the radio or something I dont wanna turn the car off, wait for the usb to load again, then resume play.
LegendRacer
il give this a shot, but my car is standard, may or maynot be the same?
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
I tested this out right now in my 2.5S Coupe and put the key far enough from the car to where the light came on saying "No Key" and it started fine.
Won't be doing that again though, even though it was nighttime and noone was around I still don't trust people enough lol
BlackNWhite
The night I initially discovered this... I was able to repeat it as many times as I wanted.
I've tried to repeat it since... but my car won't turn on.
Rob.Vegan
maybe it's a practical joke from Nissanthey wanted us to think that we discovered something new but then were let down after all the hype
Rob.Vegan
i tried it again a couple days ago and it still worked
