XJared »
https://forums.nicoclub.com/xjared-u97779.html
Tue Aug 25, 2009 3:13 pm
Not a good idea. This goes way beyond just the added back pressure on one side, you would essentially have two different engines to tune, one bank will have no or little back pressure, lower effective compression, lower combustion temps, and lots of blow through at overlap, the other will have much higher back pressure, high effective compression, more reversion on overlap, and higher combustion temps. Just run a Y pipe, but the wastegate right before the turbo so it works for both banks, and be done with it.
