interesting problems
jdmaddict1981
Car: 95' nissan pathfinder (vg30e) 2wd
ok i'm kinda new to a forum setting so here goes...,
i own a 95 nissan pathfinder XE-V6 (VG30E engine) i am in the process of buying a 95 nissan SE-V6 kingcab pickup and had an interesting idea...., i would like to drop a VG30DETT in place of the VG30E that rests there now. I do already understand i need to aquire the FSM (field service manual) for both vehicles so i could repin the ECU harness in the pickup to correctly operate the VG30DETT or so i could use the ECU from the z32 donor vehicle. The only other question or problem i am having is will the transmission bolt up to the transfer case( i.e. the 2wd models of the pathfinder and pickup use an extension housing to take up the "slack" of the driveline since there is no transfercase) i will check back on this is a couple of days (4 atmost) keep in mind i do have moderate amount of mechanical knowledge( automatics are still a mystery to me) thanks for all your responses.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
The service manual is right here for both cars: http://Nicoclub.com/FSM
Sorry I couldn't help more.
