Interesting idle problem
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
This is strange... When I start my car in the morning, and it gets up to normal temp, everything is all good (idles PERFECT).. But if I start the car when it is warm, it idles at about 550..
Scenerio (and applicible): I drive home from school, it gets up to operating temperature... Then i go inside to get my stuff, and put my golf clubs in the trunk, and then head out.. When I start the car, it idles at 550 or so, but then when I get to the course (about 2 miles away) it idles perfect again...
Its kind of like the idle is in a loop, meaning it starts at 1250, then down to 550, then back up to 700 (or whatever perfect is)
EDIT: It has done this as long as I can remember, but I figured i would post when everything has been done.....
Q45tech
Idle speed is a function of coolant temperature and time since starting. When ever it reaches 176F [actually at 160F] the speed is dropped to the preprogrammed level........IF the ecu can maintain speed by the normal amount of IAC duty cycle and ignition advance. Dirty TB and IAC or misadjusted IAC may allow lower than normal speed when warm AS A SIGNAL TO YOU to get things cleaned up or set properly!
elwesso
2007 BMW M Coupe
My IAC, TB and plenum are all sparkling???
So could this mean that hte car is running a touch too hot???
Q45tech
Sparkling? What is the IAC duty cycle in neutral warmed up [10-15% [max] and in drive - no ac on [18-20%]......then AC on [28-35%].
Correct idle speed is 650 +- 50 rpm as read on a Consult not tach.I like 675 +- 5 rpm in neutral warm no load.
elwesso
2007 BMW M Coupe
Obviously without going to a dealer I dont have any way of knowing these things....
My car needs to go in soon for the 10 year airbag inspection sometime and Ill go ahead and have them look at this too...
Q45tech
Ha! Air bag inspection.........they rot after 10-15 years and need replacing........luckily they fail softly in a puff of confetti that can't hurt or help you.........actually they do help some, even very old ones.
Isn't it nice they are only covered for 7 years
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Damn, another myth busted!
Q45tech
Just pull out your trusty analog oscilloscope and look at the IAC duty cycle.
Measure the on time vs the off time = duty cycle.
I don't expect DIY to have a Consult but they must have a decent Digital VOM with min-max hold < $50 on ebay HD-160] and some kind of oscilloscope [it can be 40 years old if it works], plus fuel pressure gauge ----even a homemade one [$20-40] and a vacuum gauge from Sears [$15].
Otherwise you are at the mercy of a dealer with a Consult.
psychic_mechanic
Car: the world's ugliest civic
At least know can tell my wife I have a reason to buy the next Gov't surplus oscilloscope I see. She doesn't dig the "I always wanted one" line.
-Vinny
Q45tech
http://www.picotech.com/auto/automotive ... 2_100.html
or a big old clunky analog unit from EBAY: Tek 2225 oscilliscope $150.
http://cgi.ebay.com/ws/eBayISA...25412h ... SA...25412
