crzycav86 »
https://forums.nicoclub.com/crzycav86-u9237.html
Tue May 25, 2004 9:25 pm
Second article was pretty interesting, but that principle would only go so far.
When you port the head, you usually port it so that the incoming air has the least turbulent path through the valve.
If you make the valve smaller, you're taking away some power(because the piston uses more power to suck in air), but you get more power because the air has more inertia, so it keeps filling the air even when the piston slows down and goes into the compression stroke.
I'd like to see if he tried this out on fuel injected engines because we don't suffer from that double carbueration problem like the bikers do.
And also, cam specs have a lot to do with this... but I have to go now. I think the point is that there are too many factors involved to prove or disprove this idea, but my gut feeling is saying that this isn't absolutely true.
