interesting DIY Welder
solarex
:ylsuper look here ...
Anand
Car: 95 Nissan 240SX
that's crazy
solarex
that's the cool part, it's actually capable of welding stainless steel
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
I USED TO ARC WELD WITH A CAR BATTERY AND CHARGER. IT WORKED GREAT WITH TWENTY THOUSANDTHS STICKS.
Mr1der
that is indeed cool, being cheap and creative rocks!
solarex
PROJECTRB240SX wrote:I USED TO ARC WELD WITH A CAR BATTERY AND CHARGER. IT WORKED GREAT WITH TWENTY THOUSANDTHS STICKS.
this guy is tig welding with that diy setup; it make me want to try that out.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
thats awesome, ive always wanted a tig welder, but there so damn expensive, and mig welding doesnt come out as clean looking for doing exhaust and ic piping work.
PROJECTRB240SX
IT WORKED FOR ME.... I'M NOT THE BEST WELDER IN THE WORLD BUT I WAS SATISFIED WITH THE RESULTS. WE USED TO HAVE THE INSTRUCTIONS TO BUILD YOUR OWN KIT WELDER THAT USED THAT STUFF AND IT HAD A CURRENT SWITCH AND AMP REGULATOR FOR HOTTER WELDS.
PROJECTRB240SX
I'LL SEE IF I CAN FIND IT AGAIN, AND IF I CAN I'LL POST IT UP HERE.
IvoryJ30t
a TIG unit?
PROJECTRB240SX
NO THE ARC WELDER SYSTEM WE USED TO USE. SOLAREX I WAS GEARING THAT TOWARDS.
IvoryJ30t
i would love to put something like that together. it'll take a lot of practice becuase ive never TIG welded, but no matter what i cant get MIG welds to come out clean like that. there is always an amount of splatter that wouldnt look good at all on home made IC piping. exhaust isnt as much as a worry, but ic piping is the first thing that catches your eye, so its gotta be good.
IvoryJ30t
PROJECTRB240SX wrote:NO THE ARC WELDER SYSTEM WE USED TO USE. SOLAREX I WAS GEARING THAT TOWARDS.
oh, how does that work [kinda welding retarded, ive only MIG'd]
just an electrode, or w/ stick?
PROJECTRB240SX
YOU PUT A CLAMP FROM THE NEGATIVE TERMINAL OF THE POWER UNIT ON THE METAL BEING WELDED AND YOU CLAMP THE POSITIVE SIDE TO A WELDING STICK (20 THOUSANDTHS WAS THE BEST ONE FOR ME) AND WELD AWAY. WITH THIS SYSTEM THERE WAS A AMPERAGE REGULATOR TO CHANGE THE HEAT OF THE ELECTRONIC DISCHARGE AND A ON/OFF SWITCH.
IvoryJ30t
oh, ok. how does that come out, does it splatter as much as MIG?
solarex
IvoryJ30t wrote:oh, ok. how does that come out, does it splatter as much as MIG?
look like he has a clean tig weld:imageimage
PROJECTRB240SX
IF YOUR GOOD ENOUGH IT COULD LOOK LIKE THAT GUYS WELDS.
I H8 UR DSM
you couldnt weld aluminum w/ that DC setup. Most people buy a TIG welder so they can weld aluminum
Stoneage_Turbo
Car: 1994 Caddy Deville 4.9
Just about anything
that dc/alternator type of welder has been around for years on 4wd trips/clubs , its how you weld parts back together mid trail so you can complete the trail and go home
solarex
I H8 UR DSM wrote:you couldnt weld aluminum w/ that DC setup. Most people buy a TIG welder so they can weld aluminum
yup; no aluminum; tig-aluminum relies on AC currents.
IvoryJ30t
oh, i get it. i just suck at welding.
Stoneage_Turbo
Just about anything
we all have to start somewhere dude , dont worry im not that good either , i susualy farmed that stuff out tot he aircraft guys to do , then i always knew it was done right
solarex
IvoryJ30t wrote:oh, i get it. i just suck at welding.
lol, that's right we all had to start somewhere. this setup is capapble of doing schedule 40 stainless steel, i gotta start my shopping list now. :thinker
IvoryJ30t
i guess once people start having yard sales in the spring, ill try to get a lawnmower or something and put one together. no sense in dropping 2 grand on a tig welder just to see that i suck at that too. i probably should try to take a class on it, its a nice thing to be able to do right.
at least i can solder real good.
solarex
IvoryJ30t wrote: i probably should try to take a class on it, its a nice thing to be able to do right.
start making friends with your local welder shop, best technique are learned on the street
