Issac »
https://forums.nicoclub.com/issac-u89863.html
Mon Mar 17, 2008 3:57 pm
CV grease is a moly grease and dark black from new. It is not a hard job, but not easy either to replace CV, but takes time, order and patience.
Need brake parts cleaner, liquid wrench,rags/paper towels, grease (good), and some common wrenches and a torque wrench would help but not necessary, and cv axle kit-Short little guys.
I got some complete assemblys for $50 each and they were new and nice. China of course. Seem fine, and actually very good. Splines were large and not rounded. Some remanufactured are sandblasted to have very little groove. Get new.
You have to take off the lower control arm bolts for the easy way to do this and there are 3 bolts (14mm)- took a breaker bar on mine to get off.
You have to take the black cap off the hub. I used the nissan lug wrench (flathead side) and a very large screwdriver on the opposite side and pop it off.
(if you want to do your wheel bearings, now is a decent time also.) Pull external clip off to release the axle shaft. Harbor freight makes a little red pin expander tool that works great- after doing this way too many times with needle nose.
Then you have a small bearing on the inboard side of the hub that the CV is kept in alignment with. It is inside the hub, outside CV- like a wheel bearing, and be careful pulling your axle out to not damage These bearings.
Clean while you are there, or you can pull this bearing and put a new inner seal in which is different from the hub bearing seal. I just reused mine just fine. Clean seal and lip and use grease on new CV, etc.
You also have to pull shaft towards wheel to release CV axle, and tap the flange that connects to the differential flange, cause they seem to stick a bit. Just a rust bond slightly. (careful doing this, see below)
Install new grease, and clean groves in hub to make for good clean fit and grease again.
Then retorque, with end wrench or long *** ratchet extension, turning... tighting...turning... tightening, until all tight. I would keep threads ungreased on these mounting bolts.
Mount the 3 bolt triangle stud for the lower control arms, no grease but cleaned, torque away. This bugger... can be just that, to get back in. It takes sliding the hub inward to the axle and be careful not to mess with your shock tower by moving hub and strut back and forth because it has no stability.
Then put clip on. If it doesn't snap in, push it close to the channel, reach around and pull CV to you, and push clip over the edge until it makes a snap. *If the space on the clip is more than a pencil width or so, Or the clip look uneven, pull and tap and seat. Then check with a tap to see that it is seated. I reused mine a few times and the right tool taking it out (H.F.) can pay for itself right away.
Tap little cap on with soft object till it seats (I use a little locktight to assist)
Wipe off the grease you were not supposed to get all over the rotor (have never been able to not do this)
The nice thing is you will not have to do it for a long time.
Seem like doing this and wheel bearings, brakes, or struts, makes for a big day but worth doing at same time.
