Interesting CEL P34C5...ever ran across this?
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
BigTasty
Car: 2010 FX35
2017 QX60, I just did the whole timing set due to chain just being worn out and loose. about 1/4" gap wiht the tensioner all the way out.
Now I am getting the P34c5 "A" Camshaft Position Actuator Control Circuit Driver Current/Temperature Too High Bank 2
It wasnt there before...maybe the unit was bad? Kind of odd.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That's an electrical error in the IVT, but you may just have "moved the furniture" on the actuator when the timing cover was off. Try having the dealer do a re-learn on the valve controller (I don't think there's any aftermarket scanner capable of doing it).
BigTasty
Car: 2010 FX35
VStar650CL wrote:
Fri Jun 09, 2023 4:30 am
Thanks for pointing me in the right direction!
I have a launch 919E diag system and I was able to calibrate it just now! woot woot!
VStar650CL
Technical Expert
:dblthumb:
Return to “Infiniti JX35 / QX60 Forum”
