Interesting Article In Drift Tengoku ...Using Heater Core as Radiator
rico05
Car: 1992 RMS13 w/ CA18DET
For starters, I am glad that DT uses a LOT of pics LOL. I can't read JDM.
The point of the article was to show using the heater core as a radiator.Pulled and mounted with zip ties to behind the radiator, inside the fan shroud, then lines from the back of the block were routed to the core. So, other than losing a heater, would this actually work? Haing a heat exchanger cooling coolant from front and rear portions of the motor sounds yummy.
i2ice4m3
Car: COUNTERSTRIKE!
It'll work...but whether it's worth it on a street car is questionable
Dattebayo
Totally worth it. When my old pulsar would overheat, all I would have to do to get the motor to cool down again was flip on the heater and suffer for a few minutes.
It totally works and would be a great alternative to huge radiators if you are running boost in really hot weather... Also you could rig up a valve between two heater cores if you wanted to keep your stock heater in place for the winter...
rico05
Oh damn that valve idea rocks! I am gonna scan the article and give this a shot!!
King 240
Car: 1992 Nissan 240sx LE
Sounds like it would work, would be very intresting. But I'm still not fully understanding where it mounts. Just right against the current radiator?
