C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Jul 02, 2004 6:59 pm
A water-to-air intercooler uses at least two heat exchangers. The intercooler itself where the water carries away the heat from the intake charge, and the radiator which takes heat away from the water.
An Air Conditioner works in a similar way but adds a very different concept to actively cool the air to lower than ambient. The compressor pushes air through the lines and into the condensor. On this side of the A/C, the freon is compressed which heats it up. The condensor cools this charge down like an intercooler. Then, it is released into the evaporator where the pressurized gas is also depressurized. This causes the freon to cool to below ambient temperatures. As it passes through the evaporator, it cools the air that goes into the car/house. Then it cycles back through the compressor and repeats the process.
