Intercooler Setup Help
VujadeMotorsports
Hi guys,
I have a intercooler setup I would like to ask about. I want to run
Water to Air Intercooler + Nitrous spraying into the front mount + Heat Exhanging Circulator Pump.
Anyone know where I can get a Heat Exchanging Pump? It is a part that big V8 guys use that keeps the water circulating at a constant 42-46degrees regardless of driving conditions.
Second, Who makes large Water To Air intercoolers? Can you guys throw me some links of the largest I can run on my RPS13?
Also.. lastly.. is there any downsides to running this type of setup?
[s3]
Why bother? If you want something really impressive try freezing your FMIC with CO2.
They do make CO2 kits that spray onto an FMIC.
Cost to HP ratio, you're setup would cost quite a few bucks and would return minimal to average gains.
A bigger turbo would gain a much bigger return for that price.
themadscientist
I was spraying Freon onto mine, tounge stuck right to it! Spearco has you covered for air to water intercoolers
