Anything is possible, cut, weld, repeat! I'm not saying it can't be done, I'm saying it shouldn't. This swap isn't even that radical in the grand scheme of things, here are some pic's from AZ Zbums site,
The mounts line up with the n/a z31 mounts although the angle is wrong. The passenger side turbo is in the way of the steering column. I know this because I did some trial fitting. Have you trail fit anything yet? I've owned a Z32TT, I had the engine in and out so many times I created my own sling and was down to under 4 hours solo, ask around thats about as fast an andy one or 2 people can pull it. The VG30DETT is a nightmare to work on, once you have it out of the car and on a bench it still takes hours to pull the turbo's. The engine uses a lot of low production, hard to find and usually expensive parts. 6 COP's, PTU, CAS, 2 Turbo's with unique Nissan flanges, the timing belt uses 2 idlers and a tensioner, you have 4 cam seals, 2 throttle bodies, 2 PCV's, one EGR but it's a bear to pull, the knock sensor is located in the valley where removal requires pulling the engine or the plenum and intake manifold, 2 boost solenoids, depending on the year 2 iicv solenoids, 2 cam solenoids, side feed injectors. As someone with a fair bit of experience with the VG30DETT, I think I'm qualified to say it's an expensive, time consuming, PITA to service, maintain and modify. IMHO this is why Z31 prices are on the rise at the same time the Z32 prices are tanking! If you really want to do it, do it! No one is stopping you. There is no how to manual, bolting the engine in the car is the easy part, it's all the extra stuff that's time consuming and difficult. If I did this swap no way' I'd try using the stock intercooelrs, you'll want somethgin like this
None of the piping would work, you would have to place ti and get a bunch of bends and couplers and start playing tetris.
Or you can add an intercooler and boost controller to a VG30ET and make 350 whp.
Speaking of bad engine swaps no one should do, here are pic's of a 3SGTE swap I did on an AW11 MR2
