The pipe to the left of the intercooler is certainly incorrect. that would route into the passenger fender.
It appears the cold pipe is missing its lower half, and you're missing the ~110° sharp angle pipe that connects the cold pipe to the intercooler.
check this link..
http://www.courtesyparts.com/M...104-3
The cold pipe they sell is all 1 piece, and the smaller section is the 110° angle bend that you're definitely missing.
as far as your BOV is concerned, having it on the cold pipe is supposed to be better somehow, but you can only really get away with it if you're running MAP. If you're running pull-through MAF, you have to recirculate the BOV and it makes it much much easier to have the bov placed on the hot pipe in order to do so.
