intercooler question guys..
tony95240sx
Car: 95 240sx-se
ok guys i just bought a 96 s14 se 240sx and i want to take out the ka engine and swap in a blacktop s13 or redtop s13 sr20det...my question is which intercooler do i buy to put with the engine..a s13 or s14 kit?
ILikeMy240sx
Car: SR Power
you go by the engine. As it is much easier to modify the brackets on the intercooler to fit your body then to modify the piping.
If you compare S14 and S13 IC piping, you will notice that the way the pipe gets routed to the throttle body is drastically different. Also, if you do get a kit that comes with a hot pipe, that is also angled differently depending on the engine.
So in short, get a S13 IC kit and modify the core to fit the body.
Ideally, you would want to get a core made for S14 and piping made for S13 SRs but Ive yet to see a kit with such combination.
tony95240sx
Car: 95 240sx-se
thanks for the reply..that makes sense..if i can get a company to mix me a s14 IC with s13 ic pipes i would be good to go? but if i decide to go with a s13 ic kit then my only problem will be mounting the ic to the front?
ILikeMy240sx
Car: SR Power
you are correct.
I know that some IC kits share a same core for both kits just comes with different brackets.
Make sure you ask exactly what the IC core difference is between their S13 and S14 kit
tony95240sx
Car: 95 240sx-se
cool thanks again...i was thinking about these ebay intercoolers..i am not really looking for a lot of HP..all i want is a clean swap with a reliable sr20det..
ILikeMy240sx
Car: SR Power
ebay intercoolers are comparable to Greddy M-Spec. The fin design is very similar along with the design of the core it self.
I was running a Greddy VSPL Intercooler until a bracket rubbed in it and punctured a hole. Next, I went with a Ebay Intercooler, which bolted up with no problem. I couldnt resist the price. It was $200 shipped for the Core, piping, couplers, t-bolt clamps. VERY VERY cheap.
The piping that comes with the IC feels like its made out of soda can... but the IC it self looks and works fine.
tony95240sx
Car: 95 240sx-se
what kind of engine do you have?i was thinking of buying the core for a s14 and buying s13 pipings
