intercooler piping
blacknissan92
Car: 92 nissan 240sx turbocharged
is relocatin the battery the easiest way
boznuttz
Car: MS13
You can get a smaller battery, relocate the battery, bend your own intercooler piping, etc. Will you use a front mount or a sidemount? What size piping are you using? Do you have access to a mandrel bending machine?
NateDogg
I got a Genesis battery from PDM-Racing.com
I bent up a piece of 1/8 aluminum and used some aftermarket battery tie down hooks to hold it down.
I fit 2.5" piping through the regular battery hole and kept the stock windshield washer reservoir.
blacknissan92
no i don't have a pipe bender
98240
you could use a mazda miata battery also. Youu might have to go to the dealership for it.
S13FX
Car: '69 l20b Dimeski :)
Just relocate that battery and remove that rusty *** battery tray for good.
PapaSmurf2k3
Site Admin
NateDogg wrote:I got a Genesis battery from PDM-Racing.com
you kept the windshield washer resevoir? im impressed.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
I plan on keeping the stock battery in place but i am bending my own intercooler piping. I dont want to relocate it to the truck because it is not a sealed battery. You can make it work. All my intercooler piping is from a electrical supply store. It is 2" electrical EMT piping.
Jookmasta
i also kept the stock battery in place........couldn't deal with the whole trunk thing as the trunk is already cramped for space. just follow IAP's design..........
hnugen
I cut out the rusty battery tray, then used an air grinder with the rotary wire to get rid of all the rust. Then I spray painted the area and put in an Odessey PC680 battery FTW!! I run 2.5" piping also.
