intercooler piping
98240
Can anyone point in the right direction to get prebent intercooler piping or does anyone have some for sale? This is for a t3 turbo and a spearco fmic. I also need a downpipe. I already posted in the classifieds and this is all I need to finish my setup. Thanks
TurboChargedSE-R
Car: 1993 Nissan SE-R with a BIG turbo
1993 Nissan 240SX convertible KA24DE-T
If you have a hacksaw/chopsaw and a free weekend, you can make your own IC pipes. On a 240 it is especially easy. Use steel or aluminum (preferred) sections, and use some strips of cardboard to mock it up on the car. Connect them with silicone couplers and t-bolt clamps and you are good to go.
If you're on a budget, most better exhaust shops can fab you up a downpipe on the spot. It won't be all glitzy and mandrel-bent....but it will work just fine.
KATwo40
Car: 1993 240sx KA-T
Agreed. I used some pre-bent pieces from Ebay and just fabbed up my own stuff. It's easy as pie.
98240
thanks guys
Iamjohnhayes
Car: 89 Single Cam Hatch
i would recomend rolling a bead or running a weld around the end of each pipe (about 1/8 to 1/4 inch from each end) it would help prevent it from blowing of under boost.
98240
thanks for the advice
What are the chances of it blowing off?
Iamjohnhayes
what kind of boost are you talking
also its more likely if you are using regular hose clamps w/o rolling the bead
usually t-clamps will let you get away w/o having a bead. unless you pushing insane boost
crzycav86
Car: 93 Nissan 240SX KAT
My pipes don't have beads, and I'm using the cheap clamps.. never had a coupler blow off.
however, i have trouble removing my couplers because they're so sticky.. i'm not using silicone ones, it's rubber but silicone reinforced. Namely, it's cheap stuff..
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
I would just weld it. Save the points of failure at the throttle body, both end tanks and the turbo. It should be pretty easy to wiggle the welded pipe into place.
Iamjohnhayes
a good intercooler should allready have the lip in the inlets and my garrett also has them.
mod240
my pipes dont have lips either and never had a prob.
98240
I will be runnung about 10psi
Iamjohnhayes
you should be fine with silicone couplers and t clamps then.
crzycav86
or **** couplers, and **** clamps. like me.
adoboboy
Car: s14
I got my IC piping from Jegs. Free shipping. just 9$ for handling.
