ibekinq wrote:you can use a 3" cold and hot pipe. no it wont induce turbo lag its cause by not enough exaust flow to make the turbine spin to its potential
Remember, the right amount of exhaust flow isn't just Given to you.
The turbo shaft is (obviously) solid, Therefore boost threshold with enormous piping produces sort of a catch 22 scenario. With 3" piping The compressor wont spin up quickly enough to pressurize the system, because there is not enough intake to produce the combustion gasses required to spin the turbine in order to do so. I mean, it'll happen eventually, but at the cost of drivability... which completely negates the reason behind owning a T-25.
I figure Nissan's pretty smart. Using a 2" hot pipe with a T25 probably had a foundation of reason.
All I want is a FMIC setup that'll efficiently cool off 16psi (when the time comes) and not be the cause of significant turbo lag. The more research I do the more I come to realize it's intercooler design that has the most effect regarding safe power output. I used to think intercoolers were "air to air radiators, nothing special here" but tried and true.. you get what you pay for.
