intercooler piping info
assAssasin
Car: 300zx na to tt soon to be vette eater
can anyone tell me how many vacuum lines connect to the ic plumbing, and where at. i would think there should be one on each pipe left and right. im trying to source some stock pipes to look at but for some reason out of all my nissan friends im the only one with a z. would it be better to just have some made, i know it would be cheaper
txQ45
Car: 91 300zx TT
If you clean out from under the hood ,, EGR and carbon cannister delete. the only vac lines you would need are the ones on each side just before the throttle bodies that go to the "in" on the Boost Controller.. And of course you would have one on each side from the recir valves
