it may sound ghetto but try PVC pipe. It has great properties.
1) It is light2) It is fairly insulative3) It is cheap4) It can withstand GREAT pressures (schedule 40 PVC can withstand 350PSI, schedule 80 pvc can withstand 450PSI , lol who is gunna boost that high anyway??)5) many couplers & reducers available (45 degree, 90 degree, etc)6) pvc glues together to make a seal that will never "blow" (no need for hose clamps)
So... get 2.5" I.D. PVC pipe and all your couplers u need for less than $30 then piece together before you glue it...then glue it and paint the pvc black so it looks like intercooler piping
I did this on my rb20det because i needed a short section of PVC and it works great! just be sure to clean out all the PVC debris before you glue together...
good luck
Tony
