Intercooler piping diameter??
crzycav86
Car: 93 Nissan 240SX KAT
What's the best size for intercooler piping on the ka?
I'm using a z31 turbo up to 9 psi and a fmic. Logic tells me to have a larger hotpipe and a smaller coldpipe if I want uniform air velocity, but what's the science behind intercooler piping? What size do the major brands use?
Discuss..
gabossie
Car: Your mom
Anywhere between 2-2.5" is pretty standard. 2" is pretty small, but you get into larger pipes (3") and spool time increases.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Z31 exit is 2"...
I've seen people reccomend 1/4" bigger than turbo exit for the hot pipe, and another 1/4" bigger for the cold pipe..
So for you: 2.25" hot pipe, 2.5" cold pipe, then a 2.5" --> 2.75" coupler for the TB. Or bump the cold pipe up to 2.75" for the last foot, if you can find 2.75" piping.
- Brian
crzycav86
:: orion :: wrote:Z31 exit is 2"...
- Brian
So why do you want the cold pipe to be bigger than the hot pipe? Won't the air already be traveling slower after it passes through the intercooler and becomes more dense? why make it travel even slower?
P.S You mentioned the same thing in FA when I did a search 2 minutes ago.
:: orion ::
Hehehe...
As the air cools, it expands...so it can maintain the same velocity in a larger pipe.
(Plus, bigger IC piping aids in off-boost response...)
- Brian
nizmo240sx_22
Car: 1992 Nissan 240sx Hatchback SE
I'm not a physics major, but I think that defies thermal expansion.
gabossie
Car: Your mom
That's what I was thinking. Cold air is MORE dense than hot air.
:: orion ::
Hehehe...I forgot the ...oops.
Let's try this again:
:: orion :: wrote:As the air cools, it expands...so it can maintain the same velocity in a larger pipe.
But the real reason is...bigger IC piping aids in off-boost response.
(Sorry, the sarcasm was lacking in my original post)
- Brian
Redline240
Car: 95 240sx
So if i wanted to use a 3" cold pipe then i should probaly use a 2.75" hot pipe...now i'm pretty sure the outlet on a T3/T04E 50trim isn't 2.5", probaly 2.25" so is there any reason i shouldn't go from 2.25"-2.75" or even 2.25-3 and have both hot and cold pipe the same size?
Redline
andrave
Car: 1989 Nissan 240SX Coupe
crazycav, I'm in houston, do you have IM?
crzycav86
Thanks for the help.
andrave wrote:crazycav, I'm in houston, do you have IM?
yeah... crzycav24
It's in my profile.
