Intercooler Mounting
GhostDrifter
Car: 91 240SX
I bought one those Mishimoto Intercoolers from ebay and it doesn't have any mounting tabs. I was wonderin how u guys mounted ur ICs. BTW i have a 91 240 Hatch
Chezedik
Car: 1991 Nissan 240sx
Seems like it would be cheap enough to weld one on. I know it's not a ton of help, but I am in the same boat, and haven't burned that bridge yet.
MarkEmark
Car: fully-built '95 240sx KA-T
If you don't want to go the welding route (I know how hard it can be to find a good aluminum tig welder), you can do what I did...I used aluminum angle brackets and riveted them to the end tanks...just make sure you know how to rivet well. And no, the intercooler did NOT leak after doing this, I tested this...the whole concept of a rivet is to expand the hole it's punched into. For insurance, you can coat the hole where the rivet goes with JB-weld, but it's unnecessary.
Titan
I'm running a Mishimoto intercooler aswell, however it has 3 threaded bosses for M12 on both the upper and lower part of the core. Yours does not?
Chezedik
I think I will rivet, but will use top of core since it has air tube in it.
crzycav86
Car: 93 Nissan 240SX KAT
you could probably just use jbweld on it.
i had the inlet/outlet jbwelded to the side of my sold tarion IC. it worked just fine.
