Intercooler help
cody180sx
Car: s14 rb25det fully built 550whp coming soon
i'm going to buy this massive intercooler for my sr but i can't find a intercooler piping kit that's not a do it your self. the inlet and outlet or 3 inches and it is a 4 inch core wat is the best option and does anybody have a kit that would fit it.
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Unless your running a supersized snail (think 600+hp) the core size will just add to turbo lag and yes it will be noticeable. If you want an intercooler that is large andcomes with piping hit eBay up for a Godspeed Project intercooler. They come with piping/silicone and the entire kit runs 250ish. I have been using their bar and plate intercoolers for a while and the only drawback is their weight but saving $500 and getting an intercooler that weighs 9lbs more is good in my book.
Yes it will require some bumper trimming and relocating or smaller battery as the piping comes up through the tray but ALL good intercoolers will require this as well.
nwmrkt
Car: S13
doridori23 wrote:Unless your running a supersized snail (think 600+hp) the core size will just add to turbo lag and yes it will be noticeable. If you want an intercooler that is large andcomes with piping hit eBay up for a Godspeed Project intercooler. They come with piping/silicone and the entire kit runs 250ish. I have been using their bar and plate intercoolers for a while and the only drawback is their weight but saving $500 and getting an intercooler that weighs 9lbs more is good in my book.
Can you help me also? Im looking at the greddy m-spec and greddy vspl, what are the main differences between them? anyother non-knockoff ones i should look at?Thanks
doridori23
The M-spec is good although mising the hotpipe an if you dont plan on going over 300 at the wheels you will be fine with this unit. The Blitz intercoolers are usually the cheapest name brand intercoolers and they have a proven bar and plate design for high flow. Check around for the best price. What is your target hp number?
eeterp
Car: 1991 240sx
absolutely! Function > Form well, in this case Get the appropriately sized FMIC.
doridori23 wrote:The M-spec is good although mising the hotpipe an if you dont plan on going over 300 at the wheels you will be fine with this unit. The Blitz intercoolers are usually the cheapest name brand intercoolers and they have a proven bar and plate design for high flow. Check around for the best price. What is your target hp number?
I'm running a Blitz LM. Fully polished, quality stuff. Check for sale threads for a used FMIC. This is a zero wear item unless the owner gets in a wreck or drives behind a dump truck full of rocks.
sr20usmcswim
Car: Nissan 240sx 1990 hatchback
your better off with an hks type r intercooler because it will handle anything. You can go to a metal warehouse and buy your own pipe
nukeone
cody180sx wrote:i'm going to buy this massive intercooler for my sr but i can't find a intercooler piping kit that's not a do it your self. the inlet and outlet or 3 inches and it is a 4 inch core wat is the best option and does anybody have a kit that would fit it.
Or, you can get a nice piping kit that will fit the 3" inlets/outlets on your intercooler from Hi Pro http://www.hiprollc.com. To get just the piping, without the intercooler, you have to call, but it is a top quality kit. Around $200 for the piping, silicon couplers, t-bolt clamps... cheaper than making it yourself! I am using their intercooler and piping kit on my RB vert and have no complaints.
