C-Kwik wrote:Are you talking about cleaning the internals or the exterior? Personally, I would use a parts cleaner or brake cleaner. Water doesn't really break down oils/grease very well.
Drift wrote:Both actually. I was just thinking after cleaning I'd mask off the endtanks and paint the core silver w/ like some high temp paint to make it look like new. So parts cleaner it is for the exterior. Now what about thru the intercooler?
C-Kwik wrote:Don't bother with high temp stuff, it's not necessary. If anything use a light coat of flat paint. You may be able to find a place that can coat it with something similar to what the OEM puts on radiators and A/C condensers. I believe these allow better heat transfer than regular paint. But my flat black paint hasn't introduced any appreciable problems.
WDRacing wrote:Simple green should never be used on metal of any kind...EVER. It brakes down the metal and weakens it, The USAF used to use it for aircraft washing, then they discovered that it broke down metal on a micro level. Simple Green is the devil...
Buy a gallon of alcohol from Ace and you'll be all set. It will evap shortly after and leave no residue.
WD
