Stoneage_Turbo wrote:hows the paint quality on yours? ones we have up here are terrible
awesome nonetheless , should be interesting with twin turbos , car fo the gods
95silviase wrote:it really depends on how often you are gonna spray. but i guess it sounds like you know what you are doing, so just dont' spray at every stop light, and i guess you will be ok. just make sure everything is set up right, you'll be fine. i guess the ideal thing would be not to, but since you are goint to, do it with some reason. i dont wanna see that amazing car with a blown motor.
Mayhem_J30 wrote:so if you're going with TT's I assume internal engine work is going to be done right?
350z33 wrote:If anything, the pistons will be changed out. As it looks, boosting at 8lbs to 10 LBS shouldnt do any harm but as usual, we will investigate fully before moving on. I believe greddys car still has the stock internals. Does anyone know what there boosting at?
Mayhem_J30 wrote:OK. I was wondering because if you're only going to boost 8-10 lbs on stock internals why go through all the trouble of twin turbos when a simple supercharger will do the same.
bpmguys wrote:What have you guys done to the car so far. We have had two 350's in out shop, one has had intake and exhaust and one has had just the intake. after numerous dyno runs there were no significant changes in hp or torque. The first car that we had, had both exhaust and intake and seemed to loose a few hp. The second had just the intake and seemed to stay about the same. On one run with the second car we saw appx 1hp increase, but nothing substantial.
350z33 wrote:The reason Im going turbo..The shop I am working with is sponsoring my car, meaning there putting most of the money into the project. I only supply the car and pay about 2K. Not a bad deal. Trust me, if the shop wasnt hooking me up, i would do the supercharger route/ cheaper and easier to install..As for 8-10lbs, make it 8- to 1 bar tops.
