I was very pleased with how well everything fit--the radius/bends of the piping/couplers were PERFECT. Everything is nice and snug.
All of the piping is aluminum mandrel-bent, 2" hot side, 2.5" cold side, that I got from http://www.burnsstainless.com
The silicone is from pegasus racing, and is very high quality and is thicker and looks to be of higher quality than the turbo hose I got from http://www.turbohoses.com
The silicone is unfortunately extremely expensive but it gets the job done. All of the hose-clamps are ones engineered for use with silicone hose.
On the cold side the second 90 deg. elbow will soon be replaced with a 45 to eliminate some bends; as soon as I can find a reputable aluminum-welder I will eliminate that skinny silicone coupling connecting the two 90 deg bends; everything else will stay as it is.
Battery is relocated to trunk, and a 3" hole was drilled through the tray.
Note the oil cooler and its thermostat behind the intercooler, the aeromotive adjustable FPR (that I was too lazy to post before--I am using no OEM FPR any more) as well as the alcohol injection/pump, which draws its source from the windshield-washer fluid reservoir.
Let me know what you guys think....
Here's the link to the album I created. Unfortunately you need to be a member of imagestation to view--I hate how websites do that. Well i think it's worth it to join and check it out
http://www.imagestation.com/al...age=Y
