Ricer240sx wrote:thanx alot guys!! hes got a clutch he might be getting rid of to...... if i use the 26 clutch would i need the flywheel too? or will it bolt up to a RB20 flywheel?? and what would the displace ment be if i were to use the crank just out of curiosity?? i probably wont but just curious...
yes you need the flywheel as well, it will bolt up.You need more than the crank, you will need pistons as well, 4AGZE Toyota ones if memory serves, it comes out to like 2.2 or 2.3.
Here is a parts list I foundFor 2.3 litresRB26 crankRB20 main bearingsRB26 rodsRB26 big end bearings4AGZE pistons and ringsBronze bush the little end on the RB26 rods to suit the 4AGZE gudgeon pinsAftermarket oversize RB20DET head gasketRB26 oil pumpRB26 water pump
