interchangeable nissan transmissions
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
keiffer671
Car: 1981 DATSUN 720 Z22
hey,
i have a 1981 datsun with a z22 2.2L 2wd. the truck is not a problem at all. As a matter of fact its a freakin beast. My problem is i have about a 20 minute drive to work on the high way at about 70mph everyday. my little 4-speed just ain't gunna cut it for daily use. I'm trying to find out what year and model of other nissan trucks/cars have 5/6 speed trans' that will bolt up and what the differance in drive shaft length will be. any help will be greatly appriciated.
-keiffer
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
The J16, L18 and Z22 use the same transmission. the transmission from a240ZX or 280ZX would work but you would need to lengthen the front half of the drive shaft 4 inches as the transmission from the ZX is a short box (its designed for ihgh rpm and high hp), where as the transmission for the Z22 is designed for low rpm, high torque.
keiffer671
i've heard that a ka transmission will bolt right up. is this true or did i hear wrong
flinterman2000
I'm not sure, do not think so. PIEZ or dogred would know if the ka transmission bolts to the z or l engine.
keiffer671
would there be any other mod i'd have to do if i swap to another transmission? would the motor even like it or would i just be wasting money?
flinterman2000
Only the usual, gearbox mount and drive shaft. You may also have to alter the entry into the cab but that is not normal.
Return to “Datsun 720”
