interchangability 5spd swap questions
silviaNE
Car: cars what else?
my wife wants me to swap her 95 240sx auto trans out for a manual. (maybe she will stop driving mine?!)
my question is as i go junkyard shoping, do i need all the parts from 95-98s or can parts from 91-94s be used. i have found lots of 91-94 parts but little of the 95-98 parts. are the sensors and mounting the same? can i use driveshafts fromeither ones? please only answer to this post if you have valid info and know what your talking about. no i thinks. thanks
P.S i have used the serach key and was unable to find proper info.i allready have wiring info and orions swap pdf.
Philsnotfalling
Car: 90 hatch 93 coupe
The trannys should be the same. I'm not sure about the sensors. The drive shaft you need will have to come out of a 95-98... which I have one in my garage that I don't need. I'm not sure about the mounts but I'm leaning towards that they are the same.
silviaNE
bump
