Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Sun Nov 09, 2008 3:11 pm
Thanks guys, When you talk about bolting the External gate shut, where are you referring to the bolt? Drilling a hole right behind the gate, and threading a bolt through the back of the plate onto the WG flap?
I've also seen some people use HKS wg actuators to drop the opening point on these turbos, so i just thought it might be a viable option.
Im using this as a circuit car so i want to keep the major engine components as simple as possible which is is obtainable (believe it or not).
I'm aware of boost creep on these manifolds, which is why mine is modified.
The external gate tubes on these are the wrong direction, so most people cut them and flip it around, i've done that, but im using a V-BAND at the area i cut it at so i have alot more flexability to run an external gate and not get stuck in one spot without having to cut it and re-weld it.
Also, assuming i go external gate, what size wg should be adequate? 40-45mm?
