Intelligent Key Recognition Issue After Remote Start Install
unistang
Car: 2011 Nissan Rogue
Hi all!
I have an ‘11 Rogue SL that’s been pretty good to me outside of many wearable parts going out much sooner than they should. I installed an idatastart remote start last year with a T-harness that only had me splice two wires outside of the parking lights. These two wires were the key-sense wire in the steering column and the intelli-key wire behind the power mirror control on the dash. I was able to solder into the key-sense wire without having to cut, but for the intelli-key connection I was required to cut and connect each side to a wire on the harness so the signal flows through the module. For these connections I used twist-it connectors because space was limited and I had some laying around. I know that I wired the thing up right. The issue that I’m having is that the car will randomly not recognize my key fob maybe 5% of the time (I-key error showing up on the dash). This happens with or without using the remote start.
I was hoping someone who knows the electronics of these cars would be able to let me know if this sounds like an issue with me not soldering my intelli-key connections or likely completely unrelated to wiring and potentially an issue with the car itself or the remote start module.
Here is the wiring diagram for reference (see pg 3): https://images.idatalink.com/vehicle-in ... 182500.pdf
I know it’s a long shot but worth a try here.
Thanks!
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Short answer... Nissan vehicles don't play nice with aftermarket remote starters. If you search through NICOclub you'll find threads by others having one issue or another with remote starters, such as acting up or suddenly not working. The solution more often than not is to remove the remote starter.
unistang
Thanks Rogue One! The thing actually works great outside of this issue (its only a random key recognition issue both using the remote start and not). I just find it odd that the one connection I didn't solder in has to do with the intelli-key system which is what I'm having issues with. With all that I've had go wrong on this car, I wouldn't be surprised if its all coincidence but its going to be a timely endeavor to get enough of the dash out to make the connection better which is why I was trying to see if anyone had a similar problem for which that was a fix.
Irregardless, I'm happy a went with a T-harness. If push were to come to shove, its pretty easy to take out.
Return to “Rogue Forum”
