Intelligent Key Question
CardiffGiant
Car: 2013 Nissan Rogue SV AWD
2013 Sentra SR with Nav/Prem/Drivers Pkg
Hi,
I have a Rogue SV with the intelligent key and I think it's very handy. However, I have one question about it that I've been unable to test for myself. If the key lets you unlock the door while in proximity, what's to keep someone from coming up to your car while you're stopped and hitting the button and unlocking your door (say a car jacker). Does it not work in that manner when the car is in gear? Just curious!
Lav22
Good question. I've never thought about that before. I'll test it out and then post my results.
sprocket
The intelligent key has antennas mounted in and out the vehicle, and is "tuned" to be able to differentiate the inside vs. outside of the car fairly well. So if you're sitting in a locked car with the key "inside" the vehicle, it would not be possible to unlock the car using the outside request switch.
Same idea when you accidentally leave the key on the driver seat or in your cupholder/console and try to lock the car from the outside, car beeps to tell you that the key was left inside the car.
You'd have to bring the key up pretty close to the glass are to possibly trick the antennas to think that the key is outside. Try it, have some fun! Roll the window down and edge the key slowly from the inside out and reach out to push the outside door request switch and see where the threshold is ... pretty impressive!
Similarly, you can have the key in your pocket in the front passenger or back seat and it can still detect that the key is inside and allow the car to start, so you don't have to actually pass the key to the driver!
Return to “Rogue Forum”
