Intelligent Key Question/ FCC# for I-key for Versa/Tiida
trrek
I own a 2006 Nissan Tiida (JDM) which is equpped with the smart key feature. I saw in the forum that the Nissan Versa in the U.S. are euipped with the intelligent (smart) key feature also
Unfortunately, I only received the mechanical transponder key and did not receive an intelligent key with the car. I was trying to source the intelligent key and the an uncut mechanical key which accompanys the remote and fits neaty inside the remote on ebay. However I am not sure what is the FCC# of the intelligent key remote that is compatible with the Nissan Versa. ( the vendor requested the FCC# in order to ensure i get the correct remote). My thought is that the same Smart key that is used for the versa can be used with my Tiida.
I checked with a local dealer and they are cluless as to what a FCC# is and from conversations with one of the sales reps they only supply the remote for keyless entry. Could anyone tell me what is the FCC# on the back of the remote so that I can purchase the correct remote? Also is there a way to code the remote or the transponder key which accompanies it without the Consult III? (since the dealer is clueless)
Thanks in advance
MaximA32
The only way to do it is to have access to CONSULT III. No CONSULT III, no programming.
trrek
thanks for the info. I was just wanted to be sure about the consult III. Do you know the FCC# for the I-key remote though?
MaximA32
I'm sorry, I don't.
I'm moving this to the Versa forum so hopefully you can get the info you need.
bdu
Car: 2008 Nissan Versa SL HB
FCC#CWTWBU729 for the ikey on my US versa. Someone's selling one on ebay here... not sure how helpful that's really going to be, though, as even if that's the right device for your car, you'll still need to get the whole thing programmed to work with your system.
trrek
Thanks Alot. I appreciate the info and asistance. As for the programming I think I will find a way . I'll let you know how it goes.
Thanks again
trrek
Thannks
trrek
Does this FCC# for the remote apply to the hatchback Tiida (Versa) or is it for the sedan? is the remote a 3-button or 4- button? as the user manual displays a 3-button remote (just making sure i buy the right thing ).
biggie
trrek wrote:Does this FCC# for the remote apply to the hatchback Tiida (Versa) or is it for the sedan? is the remote a 3-button or 4- button? as the user manual displays a 3-button remote (just making sure i buy the right thing ).
I have the same number as listed above and it is for the Hatchback and is 3 button.
trrek
Thanks much I really appreciate it.
