Intelligent Key Memory Seats?
Bloodredhog
I have an 07 M35X with intelligent key.I read the manual - is there a way to program the seats memory settings to activate when you push the button on the door handle?All I can see is a way to activate seat memory settings when you push unlock on the key fob...
Thanks
GJEMD
If you go to settings on the screen there should be a selection that takes the position to seat back steering up to enhance your exit. If this feature is activated then seat position will return to last position used. If you are the main driver, take #1. #2 should always push #1 before they take out the key and exit. I think this will solve your problem
