Well it got to send some sort of a signal continuously even when you are not pressing any buttons. The vehicle recognizes that the key is inside the car to activate the start button. Also, you can open the rear hatch without unlocking the car if the key is in your pocket. Same thing with the welcome light.sirnice wrote:I would assume some kind of radio signal and probably not continuously broadcasting it otherwise the battery would die pretty fast. I'm guessing that when you press the button on the door, it sends a query signal out to see if the key is near and then it would unlock the door.
This is just a non scientific guess.
Hmm, that makes sense. But how about the rear hatch? Even you disable the welcome light, the key needs to be verified to open the rear hatch without unlocking the car.Marconelly wrote:If you disable the welcome light function, then there's no need for the car even to emit signal every second (and it probably doesn't) - it would just emit the signal when you press the door buttons. Then only when the doors are unlocked the car would go into every-second signal mode, as to detect if the key is inside or not, and when you properly lock the car, it would stop emitting any signals again. This must be the reason the welcome light function is disabled by default, as the every-second emitter probably drains the car battery ever so slowly. In fact I've read on this forum that the welcome light function stops working if you leave the car parked for two weeks or so without unlocking it, again, to preserve the car battery.
Modified by Marconelly at 12:31 PM 3/31/2010
Sorry, I edited and added to my post probably while you were reading it. The reason why rear hatch can be opened is because there's a pressure sensor switch below that rubbery surface where you grab the rear hatch to open it. That switch acts as both the unlock request switch and the hatch opener switch.googleman wrote:
Depressing the rubber-covered switch when the car is locked only unlocks the rear hatch. Not the rest of the doors. You need to depress the silver button to do that.Marconelly wrote:Sorry, I edited and added to my post probably while you were reading it. The reason why rear hatch can be opened is because there's a pressure sensor switch below that rubbery surface where you grab the rear hatch to open it. That switch acts as both the unlock request switch and the hatch opener switch.
So when the doors are unlocked, that switch will just open the hatch, but when they are locked, it will first unlock the doors, and then open the hatch.
Our key fobs conform to FCC Part 15 Security/Remote Control Transmitter operating in the 315.0 MHz range.FCC Rule Parts 15.231googleman wrote:What kind of signal does the intelligent key use? I assume it continuously sends signals (rather than receive them) to be recognized by the vehicle. Since most of us are probably carrying the key in our pockets, I wonder if there are any long term health risks to adjacent *important* body parts!
That's good to know to avoid confusion. I'll edit my post accordingly. So if the car is locked, you can just open the rear hatch using the rubber-covered switch, then when you close the hatch, car will remain fully locked if you walk away? What in case where we change that setting in the car that one switch unlocks all doors (so that when I open drivers door, all doors unlock)? I changed it to work that way, so will in my case the rubber switch unlock all doors? I can just check that tomorrow anyway.txgcoupe wrote:
John
Some cars (eg mazda cx7) can lock themselves on walkaway...generally a great feature, wish it could be set on the EX35. That said, it needs to be optional (like the welcome light) as it can be a bit of a pain if say you park your car nightly in the garage and want to leave the car open...cant tell you how many times I just wanted to grab something from my car, got to the garage but it was locked because of this feature.Marconelly wrote:That's good to know to avoid confusion. I'll edit my post accordingly. So if the car is locked, you can just open the rear hatch using the rubber-covered switch, then when you close the hatch, car will remain fully locked if you walk away? What in case where we change that setting in the car that one switch unlocks all doors (so that when I open drivers door, all doors unlock)? I changed it to work that way, so will in my case the rubber switch unlock all doors? I can just check that tomorrow anyway.
I wish the rest of the doors could be re-programmed to work in an even more transparent way. On top of what I mentioned above, there's no technical hurdle making this car lock by itself as you walk away with the key in your pocket, and then unlock itself when you get back to it. If it can switch on welcome lights, it could unlock itself as well. All the hardware is there, it would just be a software change.
Modified by Marconelly at 8:12 PM 3/31/2010
