Intelligent Key fob question
LocoGav_13
Is there a difference between
http://www.autotransponder.com/2007_inf ... gent_key_2
and
http://www.autotransponder.com/2008_INF ... ligent_key
they are just different years, will that affect whether they will work? Significant price difference!!!
I also came across this, but not sure if it would work for the G35? Or do i just need to go to the dealership?
http://www.ehow.com/how_7255768_program ... t-key.html
biggie
Need to fix your links, you copied them from text instead of the actual URLs.
LocoGav_13
Fixed...Thanks for the heads up!!
biggie
Looks like 07 and 08 should be the same.
GAU-8
Car: 2006 Infiniti G35 sedan
Do you already have an i-key and want to add one to the car? If so, pull the key out and look at the transponder code. So long as you get one with the same code you should be good to go.
