Intelligent Key Fob Battery. Replaced after just Three Months.
bembol
Car: 2015 Nissan Murano SL AWD Cashmere Interior
That was quick. Tonight, I got a warning after starting her up. Headed over to Wal-Mart and a couple of Energizer batteries. They had Panasonic 2032 3V Lithium.
DO NOT try to separate/open them up with your nails. Your keys will work fine, simple twist.
08Coupe
Car: 2008 Altima Coupe
bembol wrote:That was quick. Tonight, I got a warning after starting her up. Headed over to Wal-Mart and a couple of Energizer batteries. They had Panasonic 2032 3V Lithium.
Doesn't it charge if u stick it in the port in the car?? If not it should be covered by nissan..IMO
blancs3030
Car: 2008 Altima Coupe 3.5L SE 6MT
it will not charge it, it just recognizes the key so you can push the start button.
blancs3030
it will not charge it, it just recognizes the key so you can push the start button. Cold weather might had drained the battery. Opps sorry for the double.
bembol
There's something wrong here, I replaced both and I'm getting a Low Battery indicator again!
My dealer said that Fob Slot is just for when the Security can't sense the Intelligent Key.
Barknard
Car: 2008 Altima Coupe, 3.5SE, 6MT
This happened to me too! I replaced the battery with a new one, but it tells me i have low battery still... anyone know a fix?
RonNJ829
Car: 2007 M-35
Same thing happened this morning to my son's 2008 Altima Coupe. I went to get the spare key, which was used maybe twice in 6 months and symbol on the dash is showing a low battery on that one
Barknard
In an attempt to find the root cause of the problem, I bought a brand new battery for my key.
While testing, I made sure that only one battery was in range of the car. I replaced one of the key batteries and walked over to the car to test. Light came on.
Still confused, I returned to replace the other keys' battery - still making sure no two keys were in range. This test failed too!
All I can think of is that the car warning needs to be switched off by the dealer... My key battery is 100% full. Anyone else have any ideas or hope? Having the light on is so annoying!
dl_yeunuoc
Car: altima coupe
Plug it in key holder after replacing new battery.
IMrGoodBarI
Car: 2008 Nissan Altima Coupe 3.5
I replaced mine a about 1 month ago and as soon as I replaced the battery the light went off. A little strange yours stays on
ctrlaltcoupe
Car: [2008 Altima Coupe 2.5S][Azure Blue with Blond Interior][6MT][Conv. Package][Moonroof]
I have a question about the keyfob battery indicator light. When the indicator light comes on, the black shaded portion of the battery drawing is 2/3 and the non-shaded portion is 1/3. I perceive this as still being 2/3 full. My brother says it looks like it is only 1/3 full, 2/3 empty. Which is it? I have approx. 17000 miles on the car, and always use the same keyfob.
