hmm the part I am talking about is this: http://www.trademotion.com/par...gid=0240z4u wrote:Gawdzilla, are you talking about the plastic shroud that sits under the radiator to fill the gap between it and the core?
haha, like i said it's often trashed cuz ppl are either lazy to replace it when it gets damaged, or they don't want to remove the 6 or so 10mm bolts that hold it on when working on the car. when you buy a used car it might not even have been on there240z4u wrote:Holy crap, I had no idea that part even existed. I am ordering one this week!
Evan
dam mine was broke and i just threw it away yesterday haha. oh well i guess ill get a new one.gawdzilla wrote:put the splash guard (shroud) under the car back in. trust me it makes a HUGE difference. if yours is broken or damaged a new one from the dealer is about $50.
I don't call them stealerships for nothing.Darius wrote:I just called the dealership to see what new upper radiator brackets cost. Nissan must have started making them out of solid copper because they quoted me $45 each!
apparently there is/was one for s13s?rb25drag wrote:What do the older s13 guys do? I don't have a splash shield on mine either. Also have an over heating problem.
Thats the lower shroud if your running the Stock clutch fan, I don't think it would be worth buying, I don't think it would cover anything.Neejay wrote:apparently there is/was one for s13s?
I might be ordering one of these too...
Hmm. Maybe that might help as well... $70 is kinda rough Maybe I can find one used in good condition.. But if it works I would be happy.Neejay wrote:apparently there is/was one for s13s?
I'd rather just buy one premade...or at least have someone print/show dimensions already.onepuff wrote:Yes ducting also helps very much in having an efficient cooling system by forcing the air to go through the radiator instead of just swirling around in the front of the car.
Anyone looking to buy the OEM splash shield, you could probably get some sheet metal and buy an air shear or electric shear and fab up your own lower ductwork for the same price and still have the tool for future projects.
Well I like fabrication!! So Ill just build that sucka!!Neejay wrote:I'd rather just buy one premade...or at least have someone print/show dimensions already.
LOL Well, I mean, if I had the resources/space I wouldn't mind trying it...but no garage + heat + apartment complex = bleh...rb25drag wrote:
That is what cardboard templates are forNeejay wrote:I'd rather just buy one premade...or at least have someone print/show dimensions already.
94-01240z4u wrote:What year teg' radiator did you use? I am up in the air between this and an aluminum koyo at this point.
Evan
I'll be running a CXracing or Mishimoto. I haven't heard anything bad about neither. Just as good for nearly half the price.kouki-gymkhana wrote:I'm running a Koyo and I kind of regret it. The rad is HUGE but the fin spacing is so tight, I don't know how much airflow is actually able to pass through the radiator. If I had to do it all over again, I would get a Griffin or C&R dual pass, or any dual pass rad for that matter. They are pricey but it is the most important part of you cooling system and these RBs run HOT.
