DriftBoy07 wrote:^ I agree with the walboro, but get the oil drain tube-people have blown their turbo seals because they kinked that metal tube to make it fit which is waste. Its worth the money! Im doing something similar, get the MAF, 550cc injectors, and put them in at the same time.
With those mods you should be able to push 300-300hp with a boost controller Check out my build if you wanna see an example, or search Clawhammer he has some good info on the subject
Sounds good, what do ya'll suggest is a safe boost level on the T28, still running on stock fuel system and maf. And then, what would be a safe boost level once 550cc injectors, fuel pump and Z32 maf are added?
