Yeah that's bananas. No wonder why our M56's feel like pigs when the weather gets hot...they probably all look like this or worse! WTH?ArmedAviator wrote:No engine detergent will help that issue, PostalsQ.
It is specific to the Direct Injected 5.6L models. The 3.7L models have port injection which keeps the intake valves clean thanks to fuel being sprayed onto them which contains detergents.
This is common of all DI engines. Some are worse than others.
Not bad other than the stupid wiring harness bracket on the passenger side that also holds the Evap filter.Ilya wrote:I use Seafoam directly into the manifold every 30kmi (vacuum source). So mine might be a tiny bit cleaner but I'm curious to see your final results. How hard was it to remove the manifold?
This is all so crazy lol. Write a good howto document so I can send it to my tuner and have him look at my maps. I probably won't go through the task of cleaning the IM but at least the other stuff.DFW2011M56S wrote:I rescaled the compensation table to go to 7,000 rpm. WOT is now in the 12.2-12.4:1 range from 3,000-7,000 rpm. I seem to be maxing out what the MAFS are programmed to read. I am seeing a steady 345.59 gm/sec across a spread of 1,000 rpm, 6,000-7,000. Can always add fuel via the compensation table but seems weird that there is a limit to the MAF reading set so low hidden somewhere in the tuning. The MAF voltage increases but the MAF flow reading flat lines. The calculated load percentage drops below 100% when the MAF reading maxes out by keeping the Base fuel numbers from rising. I need to look at the load scaling map and get that to max out at 100% for the transmissions sake.
Oh and its faster than a moded turbo Evo from a good roll, but he did get me when I tagged the rev limiter on the 1-2 from a 20 roll. I was cutouts closed and did not feel the need to draw even more attention.
The hesitation in my car is 100% without a doubt temperature related. I got it up over 210°F oil temp and that nasty hesitation that shows up in the summer time came right back. Coolant got up to 190°F with the fans at 100% duty cycle. When the car is cooler though it runs alot smoother and has better response. I think a good thermostatic oil cooler setup would help tremendously. My oil temps shot up 20°F after 2 WOT 0-70 mph runs on a 75°F day. Mileage is up as well. I cruised about 20 miles on the highway at 65-70 mph with the fuel economy display pegged above 30 mpg.
Honestly I do not see it maxing the MAF itself out. It is hitting some limit in the ECU code that is hard programed into it as a maximum airflow value.PostalsQ wrote:So would a GTR MAF be better suited for you? Maybe some redline water wetter treatment in The radiator? Would a hair cooler thermostat work? I like the oil cooler idea. And is the radiator just to small for the 5.6? Would a Mishimoto be better suited? BTW, EGT's really go down on diesels with Snow performance water/methanol. That might be the ticket for you 5.6 guys.
That is Infiniti side stepping the built-in flaw they created in this engine. The VK56 has never had enough baffling in the PCV system and they all burn oil through the PCV because of it.BlackCat81 wrote:They look like that with 10,000mi on them too. Infiniti says it's normal.
Wanna trade manifolds? lol.DFW2011M56S wrote:That is Infiniti side stepping the built-in flaw they created in this engine. The VK56 has never had enough baffling in the PCV system and they all burn oil through the PCV because of it.BlackCat81 wrote:They look like that with 10,000mi on them too. Infiniti says it's normal.
I had 2 cylinders that had valves that were not even fully seating because of the carbon buildup on them. The amount of carbon in the ports, bowls and valves was killing performance in my car.
I am up 2 mpg this week compared to last week. I am averaging 18 mpg in-town despite multiple romps to 6,500+ daily.
Also between adjusting the AFR and cleaning the ports and valves the black soot on my exhaust tips and grey haze when I lay into it have been minimized. My WOT air/fuel ratio target is 12.46:1 and I am holding it fairly consistently.
Wouldn't help you. The buildup is in the heads.Ilya wrote:Wanna trade manifolds? lol.DFW2011M56S wrote:
lol, fail. That's what I meant but was joking, that's way too much work for me so glad you're seeing results.DFW2011M56S wrote:Wouldn't help you. The buildup is in the heads.Ilya wrote:
Going to run a can of the Seafoam through mine. Do you run one side of the T fitting at a time or do you run it through the hose coming from the solenoid into the T fitting to catch both sides at once?DFW2011M56S wrote:The 3.7 as regular port fuel injection. Detergents in top tier fuel like Chevron or Shell will help keep the valves clean along with a regular dose of something like Techron.
Fuel pour in additives will do nothing for the intake valves on a DI 5.6. The cleaners I ran were intake system cleaners that you run into the engine through the PCV system or other vacuum source on the intake manifold. I used the T fitting between the throttle bodies that the purge solenoid is hooked to under the intake manifold...
I documented this when I did it...can also go that route:armybrat wrote:Going to run a can of the Seafoam through mine. Do you run one side of the T fitting at a time or do you run it through the hose coming from the solenoid into the T fitting to catch both sides at once?DFW2011M56S wrote:The 3.7 as regular port fuel injection. Detergents in top tier fuel like Chevron or Shell will help keep the valves clean along with a regular dose of something like Techron.
About 6 hours spread over 2 days. Started late in the evening and finished the next afternoon.Snake31 wrote:DFW,
Please let us know how long your power increase lasts. I'm sure it gradually declines but it would be nice to know whether this would be good to do every year or so. My car just hit 20kmi and it seems to lack power on the low end. I am considering doing this also. It would be good to document the valve condition of a 20kmi engine and perhaps smooth out the acceleration of my car. How long did this take you from start to finish, which cleaning agent did you use, and did you replace all the intake gaskets?
Looking further into using the Seafoam, I've read where a few Nissan Techs advise against it for a GDI engine (if you have a bunch of mileage on your car), because there is a possibility of carbon pieces getting between the cylinder walls and the pistons while the engine is running, causing scouring and premature engine wear. From what I've read, doing it the manual way is the best and safest way for your engine. The Seafoam may be a good option if you bought the car new and used it as part of a regular maintenance regimen, as opposed to trying to remove build up from May 2011.DFW2011M56S wrote:About 6 hours spread over 2 days. Started late in the evening and finished the next afternoon.
I used fine crushed walnut shells in a media blaster from Harbor Freight and about 5 cans of carb cleaner from Autozone. Some blue paper shop towels and some red shop rags.
Taking the intake off and re-installing it is the clean, easy part. The walnut blasting and carb cleaner are both messy and nasty.
Can you upload the pictures again if you still have them? I’m thinking that the valves in my QX56 probably need to be cleaned. I’m at 110k. I wish that they would have done like Lexus and provided both port and direct injection. It would definitely help with the carbon buildup on the intake valves.DFW2011M56S wrote: ↑Fri Dec 30, 2016 2:51 pmAbout 6 hours spread over 2 days. Started late in the evening and finished the next afternoon.Snake31 wrote:DFW,
